# Software Development Specification (Revised)
## 1. Introduction
The project delivers a ready-to-run RESTful API built with Node.js, Express, and MongoDB.
Key capabilities
1. User management with role-based access control
2. Stateless authentication via short-lived JWT access tokens and long-lived refresh tokens
3. Third-party OAuth (Facebook, Google) and traditional email/password login
4. Password-reset workflow with e-mail delivery
5. Production-grade boilerplate including error handling, logging, documentation, and automated testing
## 2. Functional Requirements
### 2.1 Configuration
The application reads and validates environment variables from `.env` (checked against `.env.example`).
Required variables
* `PORT` – HTTP listening port
* `NODE_ENV` – `development` / `test` / `production`
* `MONGO_URI` – MongoDB connection string (production / dev)
* `MONGO_URI_TESTS` – MongoDB connection string for the test suite
* `JWT_SECRET` – HMAC secret for signing JWTs
* `JWT_EXPIRATION_MINUTES` – lifetime of an access token (minutes)
* `EMAIL_HOST`, `EMAIL_PORT`, `EMAIL_USERNAME`, `EMAIL_PASSWORD` – SMTP credentials
Note – The runtime configuration property `jwtExpirationInterval` is populated from `JWT_EXPIRATION_MINUTES`.
### 2.2 Server Lifecycle
1. Read and validate env vars
2. Establish MongoDB connection
3. Start HTTP listener on `PORT`
4. Log successful startup via `config/logger.js`
### 2.3 Authentication & Authorization
| Action | Endpoint | Method | Auth | Description | Input Validation |
| Register | `/v1/auth/register` | POST | public | Create account | `email`, `password` (6–128 chars) |
| Login | `/v1/auth/login` | POST | public | Issue new tokens | `email`, `password` |
| OAuth login | `/v1/auth/facebook`, `/v1/auth/google` | POST | public | Exchange third-party `access_token` for local tokens | `access_token` |
| Refresh token | `/v1/auth/refresh-token` | POST | public | Exchange refresh token for new access token | `email`, `refreshToken` |
| Send reset link | `/v1/auth/send-password-reset` | POST | public | E-mail reset link | `email` |
| Reset password | `/v1/auth/reset-password` | POST | public | Update password using reset token | `email`, `password`, `resetToken` |
Authorization rules
* Access tokens are Bearer JWTs.
* `ADMIN` role may operate on any user.
* `LOGGED_USER` may only operate on itself (unless `ADMIN`).
* Middleware chain: `passport.authenticate('jwt')` → role guard.
### 2.4 User Management
| Action | Endpoint | Method | Required Role |
| List users | `/v1/users` | GET | `ADMIN` |
| Create user | `/v1/users` | POST | `ADMIN` |
| Get own profile | `/v1/users/profile` | GET | authenticated |
| Get user by id | `/v1/users/:userId` | GET | same user \| `ADMIN` |
| Replace user | `/v1/users/:userId` | PUT | same user \| `ADMIN` |
| Update user | `/v1/users/:userId` | PATCH | same user \| `ADMIN` |
| Delete user | `/v1/users/:userId` | DELETE | same user \| `ADMIN` |
Query parameters: `page`, `perPage`, `name`, `email`, `role`.
### 2.5 Email Delivery
* SMTP transport configured with `EMAIL_*` vars
* Templates: `passwordReset`, `passwordChange`
* Password-reset mail includes `passwordResetUrl` containing reset token
### 2.6 Documentation & Status
* `GET /v1/docs` – generated API docs
* `GET /v1/status` – simple health check (`OK`)
## 3. Non-Functional Requirements
Performance Stateless JWT auth; MongoDB indexes on token fields
Scalability Horizontally scalable; application instances are stateless
Security bcrypt password hashing (10 rounds; 1 in tests), Helmet headers, assumed HTTPS, CORS enabled
Maintainability Layered folder structure (config, middleware, services, models, controllers, routes)
Logging Console in non-production, file logs (`combined.log`, `error.log`) in production
Testing Mocha, Chai, Supertest with unit and integration suites
Constraints Node ≥ 8
## 4. Data Structures and Models
### 4.1 User (`users` collection)
Field | Type | Rules
email | String | unique, lowercase, regex, required
password | String | bcrypt hash, 6–128, required
name | String | ≤128
services.facebook / services.google | String | OAuth IDs
role | Enum `user` \| `admin` | default `user`
picture | String |
timestamps | `createdAt`, `updatedAt`
### 4.2 RefreshToken (`refresh_tokens` collection)
Field | Type | Notes
token | String (indexed) | `<userId>.<80-hex>` (40 random bytes → 80-char hex)
userId | ObjectId → User | required
userEmail | String | required
expires | Date | +30 days
### 4.3 PasswordResetToken (`password_reset_tokens` collection)
resetToken | String (indexed) | `<userId>.<80-hex>` (40 random bytes → 80-char hex)
expires | Date | +2 hours
### 4.4 JWT Payload
  exp: <unix seconds>,   // expiry = now + JWT_EXPIRATION_MINUTES
  iat: <unix seconds>,   // issued at
  sub: <userId>          // subject
## 5. Algorithms and Logic
### 5.1 Registration
if user with email exists → 409
hash password
create user document
generate accessToken (JWT)
create refresh token document (expires +30d)
return {token, user}
### 5.2 Login
find user by email
if user missing OR bcrypt.compare(password) fails → 401
generateTokenResponse(user)
### 5.3 OAuth Login
call provider API using received access_token
normalize provider response → {service,id,email,name,picture}
User.oAuthLogin():
  search by services.<service> id OR email
  if found → update missing fields
  else → create user with random uuid password
### 5.4 Token Refresh
find & remove RefreshToken by email + token
if not found OR expired → 401
issue new accessToken and new refreshToken
return response
### 5.5 Password Reset Flow
Send link
find user by email → if none → 401
create PasswordResetToken (+2h)
send email with token
Reset
find & remove PasswordResetToken by email + token
update user.password (bcrypt hash)
send confirmation email
### 5.6 Authorization Middleware (pseudo)
if !user OR role check fails → 403
attach req.user and continue
## 6. Interface Definitions
### 6.1 HTTP API
See Functional Requirement tables.
Common headers
* `Content-Type: application/json`
* `Authorization: Bearer <accessToken>` (when required)
### 6.2 Internal Services
* `authProviders.facebook(token)` → normalized user info
* `authProviders.google(token)` → normalized user info
* `emailProvider.sendPasswordReset(resetTokenDoc)`
* `emailProvider.sendPasswordChangeEmail(user)`
### 6.3 Config Modules
`config/vars.js` exports
  env,
  port,
  jwtSecret,
  jwtExpirationInterval, // derived from JWT_EXPIRATION_MINUTES
  mongo: { uri },
  logs,
  emailConfig: { host, port, username, password }
`config/logger.js` exports Winston logger with `stream.write()` for Morgan.
## 7. Error Handling and Validation
* Request validation via `express-validation` (Joi schemas)
* Middleware `error.converter` transforms unknown errors to `APIError`
* `error.handler` JSON format: `{code, message, errors?, stack?}`; stack returned only in development
* 404 handled by `error.notFound`
* HTTP status codes follow `http-status` enum
* Unique-email conflicts mapped to 409 (`User.checkDuplicateEmail`)
## 8. Technical Dependencies
Category | Packages
Web | express
Database | mongoose, MongoDB
Auth | passport, passport-jwt, passport-http-bearer, jsonwebtoken, bcryptjs
Validation | joi, express-validation
Logging | winston, morgan
Config | dotenv-safe, cross-env
Email | nodemailer, email-templates
Utilities | lodash, moment-timezone, uuid, axios, bluebird
Security / headers | helmet, cors, compression, method-override
Testing | mocha, chai, chai-as-promised, sinon, supertest, nyc
Process mgr | pm2
Docs | apidoc
## 9. Testing and Validation
Strategy
* Unit tests: models, services
* Integration tests: all API routes (`/tests/integration`)
* Test DB: `MONGO_URI_TESTS`, `NODE_ENV=test`
* Coverage via `nyc` (HTML + text + Coveralls)
Representative cases
1. Registration success & duplicate e-mail conflict
2. Login (success / wrong password / invalid input)
3. JWT expiry using Sinon timers
4. Role enforcement (`ADMIN` vs regular)
5. Refresh token (valid / invalid / expired)
6. Entire password-reset flow
7. CRUD operations with permission checks
## 10. Deployment and Configuration
### 10.1 Environment Files
`.env` – real values
`.env.example` – template including `MONGO_URI_TESTS`
### 10.2 NPM/Yarn Scripts
Command | Purpose
`yarn dev` | start with nodemon
`yarn start` | production via pm2
`yarn validate` | lint + tests
`yarn docs` | generate API docs
`docker:dev / docker:prod / docker:test` | compose variants
### 10.3 PM2
`pm2 start ./src/index.js` (or `pm2-docker` inside containers)
### 10.4 Logging
* `combined.log` and `error.log` in project root
* Console logging when `NODE_ENV !== 'production'`
### 10.5 Database
* URI from `MONGO_URI` (or `MONGO_URI_TESTS` in tests)
* Mongoose options: `useNewUrlParser`, `useUnifiedTopology`, `useCreateIndex`, `keepAlive`, `useFindAndModify=false`
### 10.6 Email
* SMTP based on `EMAIL_*`
* `transporter.verify()` executed at startup; errors are logged
### 10.7 Build & Runtime Requirements
* Node.js 8+
* Yarn
* Accessible MongoDB instance
* SMTP server for e-mails
